Hello Guest it is October 22, 2026, 05:32:55 PM
Author Topic: 23" monitor  (Read 17413 times)
23" monitor
« on: March 04, 2013, 11:55:55 PM »
I recently upgraded to a 23" monitor  and can not figure out how to get Mach 3 to fill the screen!! Any ideas I have tried everything I can think of I am running a plasma cutter only
Re: 23" monitor
« Reply #1 on: March 05, 2013, 12:30:06 AM »
Under General Config -> Screen Control tick the Auto Screen Enlarge option.
Re: 23" monitor
« Reply #2 on: March 05, 2013, 05:10:06 AM »
Tried that
Re: 23" monitor
« Reply #3 on: March 05, 2013, 08:07:18 AM »
i found that if i go to machscreen and open the set file. resetting the res(Frame Size) to 1600x950.
the default screen fills my screen. may have to adjust to fit your screen
« Last Edit: March 05, 2013, 08:09:48 AM by Kenneth »
Kenneth
Re: 23" monitor
« Reply #4 on: March 05, 2013, 10:50:09 AM »
Tried that
You have tro close and restart Mach3 for it to take effect.
Re: 23" monitor
« Reply #5 on: March 05, 2013, 12:39:15 PM »
Yes. Either that or reloading the screen in Mach3.
23" monitor
« Reply #6 on: April 07, 2013, 09:23:57 AM »
I updated to the newest Mach3 version and the same happened. No full size on the screen.
Re: 23" monitor
« Reply #7 on: April 07, 2013, 10:21:29 AM »
In general config., do you have the high res screen tick box ticked?  Do other applications fill the screen?  Could it be your monitor needs adjusting?
23" monitor
« Reply #8 on: April 09, 2013, 10:55:15 AM »
Tanks, that worked!!
