Hello Guest it is November 12, 2026, 06:37:42 AM
Author Topic: Most simple Gcode with arc problem.  (Read 10868 times)
« on: February 05, 2007, 06:31:58 AM »
Hello. I'm running the latest version of Mach3.
I have in Config/General Config set to absolute mode and IJ to incremental. The following GCode gives me problems:
G17
G21
M04
G01 X30  Y20  F200
G03 X300 Y200 I60 J34  ; <------ PROBLEM
M05
M30
It gives me: "Radius to end of arc differs from radius ..."
I added G90, G91, changed the setup to absolute IJ and everthing else I could remember ...
Thank you.
Re: Most simple Gcode with arc problem.
« Reply #1 on: February 05, 2007, 11:01:26 AM »
You're specifying the center of the arc to be 90,54. An arc with that center can't pass thru both 30,20 and 300,200. I don't think it will work in absolute IJ either.
« Reply #2 on: February 06, 2007, 03:18:01 AM »
Yes it is a gcode problem, nothing more.
Thank you.
