Hello Guest it is November 13, 2026, 10:01:51 AM
Author Topic: Adding a button to bring up the jog screen  (Read 12955 times)
« on: February 05, 2007, 02:44:27 AM »
Hi
 I am new to Mach, I am setting up a system with a touch screen. Could someone point me in the right direction as to how I can make my own screen set. (I would like to emulate the Hurco control that I am used to using). But to start with if I could edit the standard screen. I guess this is not to hard as others have made their own sets. In particular I would like a button that brings up the jog control (Tab).
Toby (UK)
Re: Adding a button to bring up the jog screen
« Reply #1 on: February 05, 2007, 12:13:37 PM »
Open the screenset in Screen4, place a button where you want and set its properties as OEM Code 50.
« Reply #2 on: February 05, 2007, 12:15:01 PM »
Oh, and for making a new screenset have a look at the video for screen4 and also the ones that Benny has done on designing LEDs and Buttons.
« Reply #3 on: February 06, 2007, 03:15:41 AM »
Hi Thanks for the help. I had no idea there is a screen designer included. Could you also tell me were I can get info on MPG jog control hardware.
Thanks again.
Toby
« Reply #4 on: February 06, 2007, 12:20:30 PM »
You only need a MPG, no other hardware is required, well that is as long as you have two spare input pins. If you dont have enough you can fit a second parallel port into your computer by getting a PCI parallel port card. MPGs can be had from varying places, Ron Rogers at www.rogersmachine.net sells one, also a guy on this forum makes ones which have extra buttons incorporated in them.
