Hello Guest it is November 22, 2026, 03:05:00 PM
Author Topic: Full Circle vs quadrants  (Read 8703 times)
« on: March 01, 2013, 10:45:40 AM »
I read in the Mach 3 manual, and elsewhere that using circular interpolation (G3)  with a full 360 degrees (or even 180) is very bad.  But I seem to see constant examples of folks doing it - some very experienced folks.
Is this business of doing a quadrant at a time just a legacy limitation, and is now OK?  Or is it still a bad idea?  or is it controller dependent?   It is a lot easier to program one block to do it, but I don't want to invite trouble ...
Re: Full Circle vs quadrants
« Reply #1 on: March 01, 2013, 11:56:36 AM »
IF you use the  IJ method for arcs then full circles are fine .
IF you use the R arc method then you should use half or quadrant based circles.
« Reply #2 on: March 01, 2013, 12:58:00 PM »
Thank you very much!
