Hello Guest it is November 22, 2026, 03:03:47 PM
Author Topic: Quick Bit of Coding Help Please  (Read 11886 times)
« on: February 26, 2013, 06:55:56 AM »
heres a snap shot of my code
G00 G41 X43.5 Y-0.5 D4
G1 Z-1
F170
G1 Y2.3
G1 X54.1 Y12.3
G1 Y-0.5
G00 Z2
G00 X43.5
G00 Z-1
G1 Z-2
G1 Y2.3
G1 X54.1 Y12.3
G1 Y-0.5
G00 Z2
G00 X43.5
why am i getting a kink as highlighted below? its not in the coding and not in the blue line, its just in the white line for the g41 command? but actually gets machined into the material
Re: Quick Bit of Coding Help Please
« Reply #1 on: February 26, 2013, 01:21:35 PM »
I would say it is a GLITCH in the TC code.  IF you run the code in reverse motion as in a conventional cut it will probably work ok.
Just a thought, (;-)TP
« Reply #2 on: February 26, 2013, 02:56:59 PM »
bugger, is there a way of reporting bugs in mach3?
« Reply #3 on: February 26, 2013, 03:07:23 PM »
Support@MachSupport.com
Just for what it is worth Mach3 is at the END of it development life.  I would not expect much more to be done to it before Mach4 comes out.
Just a thought, (;-) TP
« Reply #4 on: February 26, 2013, 05:00:44 PM »
These G41/G42 bugs are well known and have always existed. As Terry says, all you can really do is wait until Mach4 is out, sometime later this year.
I use comp all the time, and rarely see any issues like this, but when I do, I just don't use comp for that particular part.
« Reply #5 on: February 26, 2013, 06:20:46 PM »
Playing around with it here I can make it better but not perfect using your code snippet.
Can you post the complete file ?
