Hello Guest it is November 27, 2026, 08:04:52 PM
Author Topic: Clipboard support  (Read 15680 times)
Clipboard support
« on: February 26, 2013, 05:36:48 AM »
I can enter a single line of g-code by hand.
But I can neither copy from nor paste to that field.
It would be much easier and much less error-prone to past some coordinates I already have in my clipboard into that text-field.
(Or at least into the g-code list.)
Re: Clipboard support
« Reply #1 on: February 26, 2013, 08:56:26 AM »
MDI is single line only.  If you will go to edit Gcode it will open as a text or notepad and you can copy and paste all you want.
« Reply #2 on: February 26, 2013, 09:14:09 AM »
I tried pasting a single line. That's the point.
Just copy&pasting coordinates to enter that single line without the risk of typos in long coordinates.
MACH3 is often used on touch screens where typing takes a lot of time.
There's no context menu with copy&paste and CTRL+V is already taken up by some other function in the UI (bad choice of cause).
I didn't see any "edit Gcode". Will look for it.
