Hello Guest it is November 13, 2026, 10:01:22 AM
Author Topic: Making an output stay active until deactivated  (Read 23280 times)
Offline fast89
  •  165 165
« on: February 24, 2013, 02:54:25 PM »
I have an air cylinder to activate the drawbar. Made a m17 macro to activate the cylinder. It works but won't keep the cylinder active on m17. It blips the output then goes to the dwell or sleep function after the ActivateSignal(OUTPUT7) line. I'm sure i'm missing something simple here but i'm tired of fiddling with it. I just need it to hold the output on till i tell it to turn off with another macro.
Re: Making an output stay active until deactivated
« Reply #1 on: February 24, 2013, 04:04:51 PM »
Post the macro you have running.
Offline fast89
  •  165 165
« Reply #2 on: February 24, 2013, 04:37:26 PM »
All i have for M17 is
ActivateSignal(output7)
« Reply #3 on: February 24, 2013, 04:42:42 PM »
OK I see 2 explanations and they are not the same.
1st
It blips the output then goes to the" dwell or sleep function after the ActivateSignal(OUTPUT7) line".
2nd
ActivateSignal(OUTPUT7). only
Which is it going to be ??
Offline fast89
  •  165 165
« Reply #4 on: February 24, 2013, 04:47:35 PM »
i tried Sleep 10000, and Code "G4 P5000". Neither would hold the output on for the determined amount of time, just blip it.
« Reply #5 on: February 24, 2013, 04:53:04 PM »
IF you are using that
It should stay on until deactivated.  Does the output led stay on or shut off also. Is the ouput signal present at th PC and is lost in the BOB ??.
You need to verify WHERE you are loosing the signal.  PC? BOB? Cables? Relay?
Just a thought, (;-) TP
Offline fast89
  •  165 165
« Reply #6 on: February 25, 2013, 03:55:44 PM »
Ok, got some more testing done. The problem appears to be a conflict with having output 7 in a macro and also in a brain. I have a manual push button that is input #2 which will output #7 to knock a tool out. That has worked fine for a year and a half. Now i have added a macro (m17) to activate output#7 With both enabled, it will only blip output#7 and button works fine. With button removed from brain, m17 will hold the output on. And i cannot have two outputs with the same port/pin. Stumped on how to get around this.
« Reply #7 on: February 25, 2013, 04:54:39 PM »
YES there are QUIRKS in mach brains. In cases like this you are much better off using the macropump to drive the functions.
In the brains where you do a compare option it only knows to turn the ouptput ON or OFF so in your case it is constantly turning OFF the ouput even thought you turn in on somewhere else.
Offline fast89
  •  165 165
« Reply #8 on: February 25, 2013, 05:15:37 PM »
Never done a macropump. going to have to do some research
« Reply #9 on: February 25, 2013, 05:17:21 PM »
What does the brain consist of?
