Hello Guest it is November 13, 2026, 12:32:15 PM
Author Topic: Motor Tuning screen not opening  (Read 8691 times)
« on: February 20, 2013, 12:00:52 PM »
In the drop down menu under Config when i click on the motor tuning option nothing opens up.  Every other item on that menu will open except for motor tuning.  Re-install maybe?? please help!
Re: Motor Tuning screen not opening
« Reply #1 on: February 20, 2013, 05:36:53 PM »
Is the driver installed?
Try deleting the plugins from the plugins folder, assuming you dont use any. If you do then rename it to something like OldPlugins and make a new folder called plugins. Try putting the plugins back one by one if it does solve the problem.
