Hello
Guest
it is
November 13, 2026, 01:05:30 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Spindle index on Optimum D280x700 Vario Lathe
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: Spindle index on Optimum D280x700 Vario Lathe (Read 53213 times)
Carnoustie, Scotland
Re: Spindle index on Optimum D280x700 Vario Lathe
Reply #20 on:
February 21, 2013, 06:04:30 AM »
Can yo be a bit more specific about the Enables? Is it the HV Enable or ?
Reply #21 on:
February 21, 2013, 06:05:55 AM »
Ah maybe you are talking about enables on your drives? If so do you have a link to the manual?
gallenat0r
43
Reply #22 on:
February 21, 2013, 06:17:29 AM »
Yes it's the enable pins on the drive. Right now the stepper motors just go into holding mode.
Manual for CSMIO
http://www.cs-lab.eu/en/upload/pdf/UM_CSMIOIPS_ENG_rev1_2.pdf
Picture of drive
http://www.google.dk/url?sa=i&source=images&cd=&cad=rja&docid=U16_Ja__qzPptM&tbnid=wO_TV63HjG0zEM:&ved=0CAgQjRwwAA&url=http%3A%2F%2Fldomotors.en.alibaba.com%2Fproduct%2F383081808-210815450%2FM542_Stepping_Driver_Controller.html&ei=HRAmUdLuDY3WsgajqoHYCA&psig=AFQjCNH-2uXllOagfvAprSU7PqeNh4FpnA&ust=1361535389624324
Kind regards,
Jens
Reply #23 on:
February 21, 2013, 07:42:15 AM »
Do you have the documentation for these drives? Usually they can be connected to 24v signals if you have the correct size resistor in series but best check with the documentation for them.
You would just use an output from the CSMIO as the enable signal and set it up in Mach as such.
gallenat0r
43
Reply #24 on:
February 21, 2013, 09:02:34 AM »
Documenation is here:
http://www.wantmotor.com/ProductsView.asp?id=257&pid=75&sid=82
Reply #25 on:
February 21, 2013, 09:27:27 AM »
That is saying a 2K resistor in line with the enable signal for 24v.
gallenat0r
43
Reply #26 on:
February 21, 2013, 12:45:21 PM »
Thanks, how are input and outputs mapped?
Reply #27 on:
February 21, 2013, 12:49:58 PM »
I presume tyou are meaning in Mach?
There are several ways but for an output such as enable you just set port 10 pin? in Mach as the enable. The ? represents whichever output on the CSMIO you are connected to, they start at 0.
gallenat0r
43
Reply #28 on:
February 21, 2013, 12:55:07 PM »
yes that was what I meant
so always port 10 and then whether it's input or output the plugin finds out for itself?
meaning input pin 5 is port10+pin5 and output pin 5 is port10+pin5 in mach?
Last Edit: February 21, 2013, 12:58:09 PM by gallenat0r
Reply #29 on:
February 21, 2013, 01:02:12 PM »
Yes that is correct if talking about I/O on base unit. If using expansion modules then the port number will be the canbus address that the unit is set to with the dip switches.
Remember that I/O start at 0 so the pin labeled 1 on the connection board will actually be pin 0
Print
Pages:
1
2
3
4
Go Up
« previous
next »
