Hello Guest it is November 13, 2026, 12:44:49 PM
Author Topic: Spindle index on Optimum D280x700 Vario Lathe  (Read 53207 times)
Re: Spindle index on Optimum D280x700 Vario Lathe
« Reply #20 on: February 21, 2013, 06:04:30 AM »
Can yo be a bit more specific about the Enables? Is it the HV Enable or ?
« Reply #21 on: February 21, 2013, 06:05:55 AM »
Ah maybe you are talking about enables on your drives? If so do you have a link to the manual?
« Reply #23 on: February 21, 2013, 07:42:15 AM »
Do you have the documentation for these drives? Usually they can be connected to 24v signals if you have the correct size resistor in series but best check with the documentation for them.
You would just use an output from the CSMIO as the enable signal and set it up in Mach as such.
« Reply #24 on: February 21, 2013, 09:02:34 AM »
« Reply #25 on: February 21, 2013, 09:27:27 AM »
That is saying a 2K resistor in line with the enable signal for 24v.
« Reply #26 on: February 21, 2013, 12:45:21 PM »
Thanks, how are input and outputs mapped?
« Reply #27 on: February 21, 2013, 12:49:58 PM »
I presume tyou are meaning in Mach?
There are several ways but for an output such as enable you just set port 10 pin? in Mach as the enable. The ? represents whichever output on the CSMIO you are connected to, they start at 0.
« Reply #28 on: February 21, 2013, 12:55:07 PM »
yes that was what I meant :)
so always port 10 and then whether it's input or output the plugin finds out for itself?
meaning input pin 5 is port10+pin5 and output pin 5 is port10+pin5 in mach?
« Last Edit: February 21, 2013, 12:58:09 PM by gallenat0r »
« Reply #29 on: February 21, 2013, 01:02:12 PM »
Yes that is correct if talking about I/O on base unit. If using expansion modules then the port number will be the canbus address that the unit is set to with the dip switches.
Remember that I/O start at 0 so the pin labeled 1 on the connection board will actually be pin 0
