Hello Guest it is November 22, 2026, 09:06:55 AM
Author Topic: Problem with feed and speed wizard  (Read 9654 times)
« on: February 13, 2013, 01:00:36 PM »
I am having problems with the feed and speed wizard. I first select the tool dia, eg 10mm, then afterwards any values which are put in the other boxes eg Number of cutting tips, Tool units, etc and the tool dia value changes and  returns to 0.  What am I doing wrong ?
Re: Problem with feed and speed wizard
« Reply #1 on: February 13, 2013, 03:15:49 PM »
Are you pressing the enter key on your keyboard after you type in the value?
« Reply #2 on: February 14, 2013, 11:26:18 AM »
Hood, I am embarrassed to admit that i didn't press enter after value typed.
I will have to try and find a more challenging query for you to answer!
Best wishes John.
« Reply #3 on: February 14, 2013, 12:01:39 PM »
Ha ha no problem John, its a common mstake and even yet I sometimes forget to press it :D
