Hello Guest it is November 13, 2026, 04:59:29 PM
Author Topic: Need advice with two problems  (Read 11125 times)
« on: February 12, 2013, 11:23:42 PM »
The first problem, I tried updating to version 3.0.46 dated 08/02/2013 with the Mach3 Pokeys DLL v1.0.0.1 dated 11/08/2012 but I just got an error telling me to use version 1.0.30 firmware so I am using that right now. Anyone know which DLL I need to run with the latest firmware? A newer one no doubt (By the way the DLL that works with the 3.0.30 firmware is also called v1.0.0.1 ??? but dated 30/05/2012) The 3.0.46 firmware package is says it comes with the DLL but there is not one in there named Pokeys.dll, there is PokeysDevice_DLL.dll, PokeysDevice_Dll.tlb, PokeysDevice_DLL.XML, WdfCoInstaller01009.dll, winusbcoinstaller2.dll, and WUDFUpdate_01009.dll. Am I suppose to use one of these? rename it?
Second problem, I made brain to output some signals to outputs, in this case Output 18, 19, and 20, when I went into the Mach3 config for Pokeys and configured some Pokeys outputs that were wired to LEDs the Mach3 output 19 was lighting up the LED configured to output 20. Further checking showed that Mach3 brain outputs sent to 18, 19, and 20 had to be configured in Pokeys config to Mach3 outputs 17, 18, and 19. Anyone else had this bug?
Re: Need advice with two problems
« Reply #1 on: February 13, 2013, 06:44:56 PM »
Ok, my bad on the first problem, I must have written over the new dll at some point, I now see it installs it to the Mach3/plugins folder. Will see if the new version of firmware solves problem 2.
