Hello
Guest
it is
November 03, 2026, 08:47:53 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach SDK plugin questions and answers.
No plugin folder
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: No plugin folder (Read 9472 times)
cpsigns
1
No plugin folder
on:
February 12, 2013, 07:27:41 AM »
Using mach3 version r1.83.005. I wanted to add a USB wireless handset, and it says to copy the .dll file to the "Plugins" folder. There is no plugins folder.
Will this hadset work with this version, and if so, where do I copy the program too?
Tweakie.CNC
9,375
Super Kitty
Re: No plugin folder
Reply #1 on:
February 12, 2013, 07:45:49 AM »
Hi Cpsigns,
Welcome to the forum.
I have never used R1.83.005, that is going back a while, but you could try creating the Plugins folder (within the Mach folder) then copy the plugin there and see if it works, but I think it is unlikely.
Failing that download and install a later version of Mach3
http://www.machsupport.com/downloads.php
It should install in a new Mach3 folder but be sure to save your existing Mach folder (and contents) to a safe place so that any required information (.xml, lic.dat, .set etc.) can be retrieved as necessary.
Print
Pages:
1
Go Up
« previous
next »
