Hello Guest it is November 22, 2026, 12:30:21 PM
Author Topic: Shuttle Pro Plugin some questions...  (Read 9884 times)
« on: February 12, 2013, 04:52:12 AM »
Hello i have installed the shuttle pro 2.0 it is nice.
But if i move the machine with the outer ring in one direction, and then release the ring, the machine does not stop, but walk very slowly in the direction i selected. It stops not untill i rotate i Little bit over zero in the other direction?
Is this a bug? I think it should stop, when the ring is in Zero Position.
Ref all does not work. Only z-axis works when select the buttom with this setting
Offline Fastest1
  •  920 920
  • Houston, TX
Re: Shuttle Pro Plugin some questions...
« Reply #1 on: February 15, 2013, 06:33:11 AM »
I dont remember mine creeping.
« Reply #2 on: February 15, 2013, 06:44:52 PM »
Yes, it will some times continue.  If you turn the wheel back it will stop.
If you are not happy contact the shuttle pro people directly.  They stand by their product and are very helpful.  They will help you.
« Reply #3 on: February 16, 2013, 07:34:19 AM »
i use the shuttle pro about 2 years. Never had any problems with the middle position. Always stops when I release the wheel.
Alex
