Hello Guest it is October 20, 2026, 03:49:32 PM
Author Topic: Soft Limits Not Working  (Read 8739 times)
« on: February 12, 2013, 01:13:23 AM »
Still learning and enjoying the process  :)  Although I hope this is not a dumb question  ???
I've set up the Soft Max and Soft Min limits under Config/Homing/Limits.  But Mach3 lets me drive (via system hotkeys) right past them.  Is there some other step required to enable the soft limits I've set?
Thanks.
____________________
Ian B
Re: Soft Limits Not Working
« Reply #1 on: February 12, 2013, 02:01:01 AM »
You need to switch them on. Also do you home the machine?
« Reply #2 on: February 12, 2013, 03:29:45 AM »
Yes Hood.  My router is homed using a photo-interrupter switch on the X, Y & Z axes.
I'll try again tonight.  Probably user error again.
Ian B
