Hello Guest it is November 23, 2026, 12:12:11 PM
Author Topic: losing steps on Z. Yes another thread about this. how to troubleshoot  (Read 9243 times)
My Z randomly misses steps. seems to only do it on rapid Z retract, so then I lose my zero... amd BAM. Into part or table I go. Yes I do have my velocity and accel set pretty low.
Problem is it's not repeatable. it only happens when I'm 55minutes into a 1 hour job and it slams my $175 indexable cutter into the vise. Yeah me.
I've searched this board... and most of the time it's a mechanical issue. this isn't.... been down that road.
Would posting my XML help? Could switching to Sherline mode help? Does Kernel speed have any effect?
Re: losing steps on Z. Yes another thread about this. how to troubleshoot
« Reply #1 on: February 11, 2013, 08:14:58 PM »
http://www.geckodrive.com/using-heds-encoders
I was thinking of trying this. This link shows what to do with the 320x, I'm using the older 320.
I found a 1uf 35v capacitor at Radio Shack... think this would be beneficial to me?
  •  9,378 9,378
« Reply #2 on: February 12, 2013, 01:02:09 AM »
Hi Jonny,
Just my opinion…
Anything that reduces electrical noise and produces cleaner signals has to be good.
As you only seem to be having problems on the Z retract I would suggest that you reduce the Velocity and Acceleration on this axis until you find a 100% reliable setting.
(Just as an example my 100% reliable X and Y rapids are 4500mm/min @ 450mm/sec/sec whereas my Z rapids are only 1000mm/min @ 100mm/sec/sec – quite a large difference 1 : 4.5).
I don’t think you should ever assume that the issue is not of a mechanical nature, always consider all possibilities.  ;)
