Hello Guest it is October 21, 2026, 12:57:09 AM
Author Topic: changing the mouse wheel rate for zoom?  (Read 9705 times)
« on: February 10, 2013, 04:44:16 PM »
Hello Everyone,
I am new to Mach 3. I would like to change the rate at which the mouse wheel zooms in/out when you turn it. On my mouse it is incredibly slow (small increments).
Also, is there any way to set the standard zoom all area? It seems like mine zooms out to outer space when I click the left button to get it into the straight on view.
Thanks!
Cismontguy
Re: changing the mouse wheel rate for zoom?
« Reply #1 on: February 10, 2013, 05:58:59 PM »
Your scroll will be set up in your mouse properties I would imagine, nothing to do with Mach.
Toolpath being tiny could be 2 things, first is you have the display on table display and have a large table and small part or there is a line in the code that is far away from where the actual part is.
« Reply #2 on: February 10, 2013, 06:05:30 PM »
Thanks Hood, I appreciate your reply. I will check this when I get back in the workshop.
Cismontguy
« Reply #3 on: February 10, 2013, 06:15:31 PM »
If it is table view then click the display button then press Regen button and it should come into work view. If its a line in your code then not much you can do except change that line to be closer to the part if you can.
