Hello Guest it is November 01, 2026, 11:52:09 AM
Author Topic: Set chain Depth button  (Read 10790 times)
« on: February 02, 2007, 05:55:51 PM »
       Well so far I like the program. The first  problem I have is that the popup windows are way too big. I don't have a 50" monitor.
          The problem is a real issue is the set chain depth button. No matter what drawing I put in (drawn on ACAD saved R-12) the program shuts down when I use the button. It happens on every release of Lazy cam.
          I would be happy to supply any info from the error message that you need.
        It also crashes if I try to use the Origin.
           Any ideas, hints, best guesses Can I borrow a sledge to threaten it to work...  :) :) :)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Set chain Depth button
« Reply #1 on: February 02, 2007, 08:39:10 PM »
Hi, Elcam
This problem has existed for some time, It doesn't bother some computers, It has been an on-again, off-again problem for me.
This is a on-going development program, Use the right hand lower Layer/Object Porop... for entering your cut depth, each layer has
only one depth, if you need different depth on an item right click on it, assign it to a different layer.
Use the Set origin min button to set origin, it works fine you just cant move into the drawing.
Brian posted, It may be a Graphics Issue causing this, Fix in the works I hope.
Hope this Helps, Chip
« Reply #2 on: February 02, 2007, 09:03:21 PM »
Hmm didn't know why I didn't think graphics. Haven't had an issue like that since the old 486. I'll turn off the acelleration etc and see if it makes a difference.
    I have been doing it through layercontrol at the top and that works.
     One other thing I noticed was the drawing locks up if you use the remove redundant button. It doesn't close the program just locks up the drawing. I can load it or another drawing and it's back to normal.
      I realize it's under development. It's going to be a great program when finished.
Offline Chip
  •  2,055 2,055
« Reply #3 on: February 02, 2007, 09:37:35 PM »
Hi, Elcam
Remove Redundant dosn't lockup hear.
Thanks, Chip
