Hello Guest it is October 21, 2026, 11:37:43 AM
Author Topic: Mirror Lasering With Shades  (Read 118633 times)
Re: Mirror Lasering With Shades
« Reply #10 on: February 11, 2013, 08:24:04 AM »
Outstanding Jeff!   :)
  •  9,374 9,374
« Reply #11 on: February 11, 2013, 09:59:00 AM »
Brilliant work indeed.  8)
« Reply #12 on: February 11, 2013, 10:03:03 AM »
Thanks Brett and Tweakie.
Jeff
Extensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925 and the Mini Laser Engraver
« Reply #13 on: February 11, 2013, 12:35:33 PM »
"white artist canvas"
Fantastic.  Good going, Jeff.  Another brilliant innovation from you.  You continue to push the state of the art even higher.
John
« Reply #14 on: February 11, 2013, 04:09:34 PM »
Thanks for the compliment and the paint to do it with John.  ;D
« Reply #15 on: February 20, 2013, 12:20:05 PM »
Used the artist canvas that Jeff discovered to laser this one.  Clear lacquer spray for protection.  Size 6 x 8 inches.
Thanks Jeff.
« Reply #16 on: February 20, 2013, 12:54:55 PM »
Very Nice!
« Reply #17 on: February 20, 2013, 09:08:48 PM »
Very nice John,
That came out very good. Looks like you varied the power instead of pulsing. I tried to use analog modulation on the artist canvas and just could not get it to come out that good. Please give us details on your settings.
Jeff
« Reply #18 on: February 20, 2013, 10:42:24 PM »
Thanks Jeff,
I used .007" resolution at 35ipm, max. power, and laser output setting.  I was also careful to not wipe off the burn residue before spraying on a light coat of clear lacquer.
I think a lot depends on the original image.  I'm still trying to get a handle on that aspect; I just don't post my failures  :D
John
« Reply #19 on: February 21, 2013, 06:25:53 AM »
Thanks John,
That's one thing I did not try (laser output setting) and I was not patient enough to run them at a lower feedrate.  ::) They came out OK, but was to light. Nothing good enough to brag about yet. I'm looking into a 10W laser to mount on the new build. It's a rack and pinion servo system and can run at 525IPM max with the 48V power supply I used.
Jeff
