Hello Guest it is November 13, 2026, 06:37:28 PM
Author Topic: VBscript  (Read 9481 times)
VBscript
« on: January 23, 2013, 11:25:23 AM »
Hello
I need a VBScript which turned off OUTPUT 1 (spindle relay)  when activated input 1
I tried two ways but no result:
1.
ActivateSignal(OUTPUT1)
If Not(IsActive(INPUT13)) Then
DeActivateSignal(OUTPUT1)
If (IsActive(INPUT13)) Then
End If
End If
End If
End If
2.
DoSpinCW()
Message "Spindle Start Requested"
ActivateSignal(OUTPUT4)
DoSpinStop()
Message "Spindle Stop"
IsActive(INPUT1)
Re: VBscript
« Reply #1 on: January 23, 2013, 02:00:08 PM »
IF Isactive(input1) then      'If signal "input1" is active
DeActivateSignal(output1)  ' Turn off output1
End If
End
(;-)TP
Re: VBscript
« Reply #2 on: January 24, 2013, 11:24:37 AM »
thanks now it works.
I have another question whether it is possible to write a VBScript:
1. When the axis moving the turn off relay (output1)
2. When the axis is not moving the turn on relay (output1)
Re: VBscript
« Reply #3 on: January 24, 2013, 01:03:25 PM »
When you say" When the axis moving the turn" do you mean a specific axis such as X or ANY axis in general XYorZ?
Re: VBscript
« Reply #4 on: January 25, 2013, 03:41:50 AM »
Yes I was thinking about A-axis.
My machine uses a 4-axis in the tangential mode.
Is it possible to write a VB script to turn off relay when moving the A-axis, and the relay turns on again when the A-axis is not moving.
I was thinking, for example:
when using OEM DRO 809 (showing velocity) to turn off relay , when not in use OEM DRO 809 the turn on the relay.
