Hello Guest it is November 07, 2026, 05:20:00 PM
Author Topic: 32-bit vs. 64-bit VBScript support  (Read 10372 times)
« on: January 15, 2013, 10:12:04 PM »
I'm running Windows 7 64-bit.
I have a .m1s script that uses a 32-bit .ocx to perform serial communications. I have an issue where I get an ActiveX error now that I've upgraded to 64-bit.
Based on the link at bottom, I think Mach is using Windows\system32\wscript.exe (or cscript.exe) to execute macros, but in 64-bit Windows, system32 holds only the 64-bit script interpreters, which can't use existing 32-bit .ocx or .dll libraries. In other words, my existing scripts might actually work if Mach called the 32-bit script interpreters now located in Windows\WoW64\
Is there a way I can select which interpreter is called to run scripts? If not, could one be added? Has anyone else run into this yet?
This is what I think is happening: http://stackoverflow.com/questions/2429477/cannot-use-createobject-from-vb-scripts-on-windows-7
Re: 32-bit vs. 64-bit VBScript support
« Reply #1 on: January 16, 2013, 05:28:19 PM »
Mach3 uses Cypress Enable as it's scripting engine.
http://www.cypressinc.com/
« Reply #2 on: January 16, 2013, 07:55:20 PM »
Thank you -- that will at least help me investigate further.
« Reply #3 on: January 16, 2013, 08:17:33 PM »
I don't think that the scripting engine is 64 bit compatible.
Just a thought, (;-) TP
