Hello Guest it is October 17, 2026, 01:52:36 PM
Author Topic: Urgent help needed. Setting up MACH 3  (Read 47706 times)
Re: Urgent help needed. Setting up MACH 3
« Reply #30 on: January 14, 2013, 12:38:53 PM »
No other outputs are set
is there a way that I can post pictures on here of screenshots, would help to show what my mach settings are.
Thank you.
I may have to leave this to worry about tomorrow, are you going to be on the forums tomorrow too, I really must try get this machine up and running asap.
« Reply #31 on: January 14, 2013, 12:40:12 PM »
i've sent you my contact details
« Reply #32 on: January 15, 2013, 05:35:51 AM »
Here is the information provided by DIYcnc for my mach3 configuration.
http://www.diycnc.co.uk/html/wiring.html
http://www.diycnc.co.uk/SYS4C.pdf
Here are my mach3 settings as I have them now:
Where am I going wrong? I plug in the system4 driver unit with the parallel port but nothing is happening. motors arent making a sound or moving when I jog the keys on Mach3 even though the DRO's changes
« Reply #33 on: January 15, 2013, 05:39:20 AM »
http://tinypic.com/r/xrkvd/6
http://tinypic.com/r/ilf991/6
http://tinypic.com/r/sgrfyb/6
http://tinypic.com/r/2vvv0qo/6
  •  9,374 9,374
« Reply #34 on: January 15, 2013, 07:52:01 AM »
Peter,
I am still not certain if your stepper motors are locking up when you have everything powered on.
Do they lock ??
« Reply #35 on: January 15, 2013, 08:52:24 AM »
They are not locked. Sometimes if i turn the system 4c off  the LED's light up and and there is some brief sounds of power. This also happens when I turn the system on but it is very brief and then they are still and silent but not locked
  •  9,374 9,374
« Reply #36 on: January 15, 2013, 10:28:45 AM »
Using a multi-meter on continuity range, unplug one of your motors then identify the A / #A windings and the B / #B windings then check that they connect to the correct pins on your controller.
Using the multi-meter on dc volts range, check the output of your 24 – 30 Volt PSU and also check that it is connected with the correct polarity to your controller / driver cards.
From reading your technical data, it is my understanding that your controller has internal pull-ups and will operate without the charge pump signal.
Therefore;
With your PC switched off and the parallel port cable disconnected from the PC if you switch on your controller the motors should lock.
