Hello Guest it is October 17, 2026, 01:52:54 PM
Author Topic: Urgent help needed. Setting up MACH 3  (Read 47707 times)
Re: Urgent help needed. Setting up MACH 3
« Reply #20 on: January 14, 2013, 11:52:22 AM »
I Have just done this test on my parallel
http://www.youtube.com/watch?feature=player_embedded&v=uglCm_qsojk#!
my pins are workings. I was getting a voltage of about 3.2
This Dell PC was recommended to me by the folks over at CNCZONE whom said they have used this PC and its parallel for Mach and it was working fine.
My driver system is £300 of kit so I really hope that it will work.
« Reply #21 on: January 14, 2013, 11:53:34 AM »
What should I do? Really stuck here
« Reply #22 on: January 14, 2013, 12:05:15 PM »
Output 1 is enabled on my mach3 ports and pins settings, still nothing
« Reply #23 on: January 14, 2013, 12:06:41 PM »
are you in the uk
« Reply #24 on: January 14, 2013, 12:07:42 PM »
« Reply #25 on: January 14, 2013, 12:17:33 PM »
You need to set the "charge pump output" to pin 1. This is in...config/ ports and pins/ output signals/
« Reply #26 on: January 14, 2013, 12:27:23 PM »
Yes I am in the UK.
I just read the Charge Pump Circuit paragraph in the manual
Perhaps I haven't set the charge pump correctly, would you be able to tell me how in the MACH3 settings?
Is the EPP something that needs to be done to make it work? How do I set this.
I am a newbie to all of this and I thank you for your help.
« Reply #27 on: January 14, 2013, 12:30:27 PM »
Thanks I have set it to:
Charge pump Green, port 1, pin number 1, red.
Still no reaction from my system
« Reply #28 on: January 14, 2013, 12:33:46 PM »
is the enable led on
do you have any other outputs set on pin 1, if so change them
« Last Edit: January 14, 2013, 12:36:01 PM by angel tech »
« Reply #29 on: January 14, 2013, 12:36:01 PM »
No, just the first and third LED are on
