Hello Guest it is November 13, 2026, 01:00:34 PM
Author Topic: Need help - Machine going nutz!!  (Read 41680 times)
Re: Need help - Machine going nutz!!
« Reply #10 on: January 13, 2013, 03:02:38 PM »
Which?
« Reply #11 on: January 13, 2013, 03:10:46 PM »
both.  i even switch the x and the z driver and the problem follows the axis not the driver
« Reply #12 on: January 13, 2013, 03:18:59 PM »
Cant see how it can be on both if one axis physically reverses when you reverse the jogging.
Were you checking on the computers port with the cable removed?
« Reply #13 on: January 13, 2013, 03:21:00 PM »
I checked the cable coming from the controller uplugged at the PC end
« Reply #14 on: January 13, 2013, 03:23:49 PM »
Check direct on the port if you can.
Just to be sure I am understanding, when all is plugged in and you Jog Y both Y and slaved axis move but when you jog the other way the Y reverses but slave continues the same direction as it was previously going?
« Reply #15 on: January 13, 2013, 03:27:47 PM »
yes.  for the y axis yes.  for the x axis, it only goes left.  z is aok.  i switched the x and the z axis direclty on the board, it still only travells left. if i change it in the software, it only travels left.  this all the sudden happend today.  i have cut about 40 hours so far on the machine and now i have this issue.
« Reply #16 on: January 13, 2013, 03:30:53 PM »
I can not understand how it can possibly stay at 5v on pin 3 when you change jogging direction if the axis does respond and reverse.
Make sure you are checking the correct pins, the manual shows the view from the computers port perspective.
« Reply #17 on: January 13, 2013, 04:35:31 PM »
Ok, Can anyone call me to go over this?  is it the pc, cable or mach 3 giving issues.  i am lost.  this was working since december.  now it is acting up??  message me for phone number.
Thanks!!
« Reply #18 on: January 13, 2013, 06:54:37 PM »
After unpluging the y and a axis' (slaved) and switching drivers bewteen them it worked.  switched them back it stayed working.  bad driver?
« Reply #19 on: January 13, 2013, 06:59:30 PM »
Bad wiring connections I would say is more likely.
