Hello Guest it is November 22, 2026, 09:42:33 AM
Author Topic: Dolphin Lathe tool dra files  (Read 24387 times)
Re: Dolphin Lathe tool dra files
« Reply #10 on: January 14, 2013, 02:00:36 AM »
That would be good Rich.
I will have to do some smaller section tools (12mm) in a bit for the wee lathe so will also put them here.
« Reply #11 on: January 14, 2013, 07:13:54 PM »
Ok heres some 12mm section tools
SDJCR 1212 in  0.2, 0.4mm and 0.8 nose rads
12mm section external threading tool for 16mm insert
Also attached is a dra for a 17mm 2x Dia
« Reply #12 on: January 27, 2013, 07:05:33 AM »
Thanks, Hood, I too have Partmaster (Dolphin) Turn. The metric tool dra files will come in handy.
Thanks again.
Norbert
« Reply #13 on: February 12, 2013, 01:51:05 PM »
Hi Hood,
Thanks for sharing your work.
To make these tools do you use DCAD to draw the tool or some other program then export as dxf and import in DCAD then save din .dra?
In other words, what process do you follow to make those tools?
Gaston
« Reply #14 on: February 12, 2013, 03:19:27 PM »
Some of them i drew in cad others I downloaded from the tool makers site as dxf. You put the DXF into DCAD and trace round the tip first making sure you call it Tip and then you can trace round any other parts of the tool you wish to show. There are instructions in the Turn Help files, open the Help and on the Search tab type in Tooling and when you press list topics you should see as in pic below, click on the "Tooling - Define Turning Tool Using a Drawing" then press display and you should get the info.
Its fairly easy to do but you have to orient the tool, pick the correct datum  and fill in the angles/names etc all correctly or it doesnt work right.
« Reply #15 on: February 13, 2013, 07:30:52 PM »
Thanks for the info Hood.
Gaston
