Hello Guest it is October 20, 2026, 05:39:11 PM
Author Topic: Help: 10x error in DRO and real movement....  (Read 8596 times)
« on: January 07, 2013, 01:16:39 PM »
Setup: Sherline 5410 (mm machine, 1 rev = 1mm) , G540 (10 microstepping), KL23H2100-35-4B motors (200 steps/rev)
When I installed Mach3 with G540 inst file I had 20000 in Motor tuning/Steps per. Problem is that my DRO shows +1.00 (mm) when I move +10 (mm). Othervise systems works fine.
On the other hand if I follow the instructions I should have 2000 in 'Steps per' becouse 200 x 10 x 1 = 2000. If I use 2000 then DRO is ok but mill is super (10x) slow.
I'm doing something silly, just don't know what. ???
Re: Help: 10x error in DRO and real movement....
« Reply #1 on: January 07, 2013, 02:57:34 PM »
2000 is correct if your screws are indeed 1mm pitch.
It is the Velocity in Motor tuning that sets the rapid speed, sounds like you need to increase that.
« Reply #2 on: January 07, 2013, 03:12:55 PM »
 ;D
I did try that at some point but something else most been wrong at that time...... so simple, now it works!
THANKS   ;D ;D ;D
