Hello
Guest
it is
November 13, 2026, 05:22:11 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
VB and the development of wizards
Grooving wizard not posting
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Grooving wizard not posting (Read 8795 times)
j2mariashop
69
on:
January 06, 2013, 05:08:06 PM »
I'm using Version R3.042.040 and Mach Turn and seem to have a problem posting the code from the OD Grooving Wizard after entering all the relevant values. I am new to grooving on the lathe and am not sure if I have the right values
G90
Groove depth=0.0689
Groove width=0.1181
X Start = 0.5906
Z Start = -0.4330
Tool width = 0.05
Pecking feedrate = 0.0120 (?) Pecking depth = 0.03 (?)
Finish feedrate = 0.0002 Finish cut = 0.0001
Stepover % = 0.0% (?)
When I try to post it does not generate the code.
Any ideas?
Joe
Logged
Carnoustie, Scotland
Re: Grooving wizard not posting
Reply #1 on:
January 06, 2013, 05:31:39 PM »
You will need to enter a step over value, it is a % of your tool width so maybe 90 to 100% would suit.
Logged
j2mariashop
69
Reply #2 on:
January 06, 2013, 07:12:47 PM »
Ah! It works! I put in 90% and the code posted. I guess step over is the equivalent of the overlap in tool motion (in Smid) as the tool moves from one edge to the other?
Many thanks, Sir!
Joe
Logged
Reply #3 on:
January 07, 2013, 02:08:20 AM »
Yes, just the amount the tool moves over on each plunge, probably 100% would be fine for a grooving operation but 90 should also work fine.
Logged
Print
Pages:
1
Go Up
« previous
next »
