Hello Guest it is October 21, 2026, 03:13:55 AM
Author Topic: How to split gcode into 2 parts or more..  (Read 15889 times)
« on: January 06, 2013, 12:40:05 AM »
I am using cam softwares like aspire and artcam to design and generate gcodes..there are some designs which take 7-8 hrs to cut .. so there
is anyway to split gcode into 2 parts or more..
Re: How to split gcode into 2 parts or more..
« Reply #1 on: January 06, 2013, 01:02:39 AM »
Those are questions to ask YOUR cam software people.
  •  9,374 9,374
« Reply #2 on: January 06, 2013, 02:46:52 AM »
Hi Anant,
Sorry to make a dumb comment but I am relating to a recent discussion in another thread...
I think that if I had spent a couple of thousand dollars on purchasing Aspire and Artcam I would be reading the manuals to learn how to use them.
« Reply #3 on: January 06, 2013, 05:41:51 AM »
3AM on a Saturday night (now what could I read into that? LOL)
My advise to splitting programs is to only post one tool to a gCode file. Or create some new text files by cut and past at a tool change and use a safe start stop routine.
« Reply #4 on: January 06, 2013, 07:24:22 AM »
A 7 hour cut in Aspire is likely to be a 3D finishing operation. The toolpath area is determined by a boundary vector. By drawing multiple boundary vectors across the area, you can create smaller areas that can be run separately.
However, if you're carving wood, it's possible that it could move overnight from stresses in the previous cut area, and you may see the border between the multiple sections.
You also need to rezero the tool the next day to exactly the same place, or you'll again see a border.
