Hello Guest it is October 21, 2026, 05:05:02 AM
Author Topic: Staying with the same (0,0,0)  (Read 10547 times)
« on: January 04, 2013, 12:14:29 PM »
Does someone knows a trick how to preserve the location. I want to drill, get the  piece out, and then return it to the machine and continue drilling. Its important to be exactly in the same position, not even a millimeter away. i mean in position, the piece height and location.
Re: Staying with the same (0,0,0)
« Reply #1 on: January 04, 2013, 12:17:25 PM »
Just have to touch off the part before you start to zero the work coords and then do the same when you place it back on the machine.
« Reply #2 on: January 04, 2013, 12:37:53 PM »
let me explain more. I want to take the part out of the machine, put some covering layer (20nm) and then back inside. I have a channel of 4mm and i want to widen it to 5 mm.  How can I put the piece in the same height and location as it was before, so i will hit the channel exactly as before? (it is really important to keep exactly in the same place).
« Reply #3 on: January 04, 2013, 01:21:36 PM »
Afraid I dont understand  what you are meaning by a covering layer, is this just on the top or all over?
Is the covering layer exactly 20mm or is it just roughly?
« Reply #4 on: January 04, 2013, 01:50:23 PM »
Just build a locating  JIG to hold the part at location.
(:-)TP
