Hello Guest it is November 11, 2026, 11:24:07 PM
Author Topic: Problem with Arcs  (Read 7597 times)
Offline viz
  •  17 17
Problem with Arcs
« on: January 04, 2013, 04:07:25 AM »
Hi, my tool diameter is D6mm.
If in program i make radius on corner R3, mach3 don't understand how to do it. Here is attached screen.
Green dots are the way my tool is going by.
If i make my corners with radius R3.1 everything works fine. Cam program is sheetcam.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Problem with Arcs
« Reply #1 on: January 04, 2013, 08:04:03 AM »
you can not have a G02 or G03 with a radius of zero, if you tell Mach3 your tool is 2,999mm it will work.
