Hello
Guest
it is
October 20, 2026, 02:55:01 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
All axis move in one direction
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: All axis move in one direction (Read 15687 times)
ronar
8
on:
December 30, 2012, 02:23:19 PM »
The axis (x,y,z) all move just in one direction! at the beginning the machine motors span OK, but then stuck on one direction. I tried changing to parallel port (ECP), it did not work. I work with Sherline CNC, Mach3 program. Any other suggestion
Last Edit: December 30, 2012, 02:24:57 PM by ronar
Logged
angel tech
499
Re: All axis move in one direction
Reply #1 on:
December 30, 2012, 03:10:20 PM »
have you set it to sherline mode
Logged
ronar
8
Reply #2 on:
December 30, 2012, 03:18:31 PM »
do you mean sherline half speed, in config->pin something ? if you mean that, then yes. If not, please explain.
Logged
angel tech
499
Reply #3 on:
December 30, 2012, 03:20:52 PM »
i've not used a sherline machine and yes that is what i was suggesting. That's all i could think of given the info you've supplied
Logged
ronar
8
Reply #4 on:
December 30, 2012, 03:28:54 PM »
what other info will help?
I change my settings according to this
http://www.bluumaxcnc.com/Mach3-Setup.html
I just can't figure out what can make the machine start working on one direction, when at the first steps it was ok.
I put in the MDI window the command: g01 x-5 f50 (is there something wrong with that?)
Logged
angel tech
499
Reply #5 on:
December 30, 2012, 03:36:15 PM »
again i've no experience with the sherline, so it's hard to give specific advice regarding it. Check you have a good ground connection, and check that the direction pulse is correctly switching.
Logged
Reply #6 on:
December 30, 2012, 03:40:20 PM »
ronar,
Post your xml file and someone will take a look and see how you have Mach configured.
Logged
ronar
8
Reply #7 on:
December 31, 2012, 07:17:29 AM »
Here is my config.
Logged
Carnoustie, Scotland
Reply #8 on:
December 31, 2012, 08:20:31 AM »
Dont see anything wrong in your motor setup page, assuming you have the correct pins assigned it should work fine.
If you have a voltmeter you could check on the Dir pin of each axis direct on the port. Connect the voltmeter between pin 2 and 25 and jog X one way then the other and you should see the voltage go between 0v and 5v or vice versa. Do the same for pin 4 and jog Y and then pin 6 and Jog Z.
Logged
ronar
8
Reply #9 on:
January 04, 2013, 12:08:27 PM »
I appreciate your suggestions. The problem was indeed the voltage. I changed the card (pic to parallel port) , and now it work :-)
Logged
Print
Pages:
1
Go Up
« previous
next »
