Hello Guest it is November 13, 2026, 04:59:40 PM
Author Topic: PoKeys to control external devices, right choices ?  (Read 11192 times)
« on: December 13, 2012, 04:37:02 PM »
hi,
I am a bit new to PoKeys. I do have a cnc, running with smooth stepper. I would like to add more output ports to trigger external devices (liquid dispenser, air...)
So far, i think using "Brains" to trigger the outputs from mach3 in oder to activate the external devices.
Is the PoKeys the right choice as an extension board ?
Thanks, Pe
Offline NeoTO
  •  504 504
    • PoLabs
Re: PoKeys to control external devices, right choices ?
« Reply #1 on: December 14, 2012, 12:54:21 AM »
Hi, Pe
You can still use Brains with the PoKeys device. PoKeys can be configured to output values from different sources - LEDs, Mach IOs.
If you have any questions, feel free to ask here.
Matevž
