Hello Guest it is November 13, 2026, 05:55:36 PM
Author Topic: Calling plugin from G-Code/Macro  (Read 7797 times)
« on: December 13, 2012, 07:13:56 AM »
is it possible to call a function in a plugin from g-code as in calling a script from g-code which in turn call the plugin? Is the only interface the NotifyPlugin call? I'm guessing the value sent to NotifyPlugin should be unique then to avoid conflicts?
regards
HÃ¥vard
Re: Calling plugin from G-Code/Macro
« Reply #1 on: December 13, 2012, 10:52:16 AM »
You could put your plugin call in a macro then call that macro from Gcode.
