Hello Guest it is November 25, 2026, 03:09:53 AM
Author Topic: Would like to Mill circle with Galil setup  (Read 9797 times)
« on: December 10, 2012, 08:12:43 PM »
I have mach 3 running thru Galil. Is there any way I can mill a circle going thru the Galil set up. Sorry-this is beyond me
racear
Re: Would like to Mill circle with Galil setup
« Reply #1 on: December 11, 2012, 01:04:54 PM »
You can do it using vector mode and other commands to specify radius of arc segments and angles but if you have Mach3, why not just use the built in wizards? That is the easiest way.
