Hello Guest it is November 13, 2026, 05:10:15 PM
Author Topic: Units/Min Issues  (Read 20664 times)
Offline Telad
  •  13 13
Units/Min Issues
« on: December 06, 2012, 02:26:37 PM »
Hello,
My CNC machine is working correctly and cutting out my part to spec; however the display for units/min seems to be 2x the actual speed.
See attached.  Any ideas?  I asked in the general support and Hood suggested I try here.
I'm using the latest "lock down" demo version (soon to be licensed).
Offline NeoTO
  •  504 504
    • PoLabs
Re: Units/Min Issues
« Reply #1 on: December 06, 2012, 11:12:08 PM »
We will take a look at this, but may take a while.
Offline Telad
  •  13 13
« Reply #2 on: December 07, 2012, 09:10:08 AM »
So I take it in your system it displays the same?  In other words is this a known issue?
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: December 07, 2012, 12:57:58 PM »
Mach3 with stepper motors works in the open-loop control and controls the feedrate in advance. I am not aware on how the units/min is calculated and can not advise you here until we contact Mach3 authors.
Offline Telad
  •  13 13
« Reply #4 on: December 18, 2012, 10:43:32 PM »
Any update on this issue?
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #5 on: December 21, 2012, 03:16:39 AM »
Still waiting for an answer from Brian...
« Reply #6 on: April 05, 2015, 04:17:11 AM »
Is there an answer to this issue ??? after 3yr ?
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #7 on: April 26, 2015, 01:00:58 AM »
Have you tried the latest plugin? Quite a few versions back, the speed filtering has been applied.
