Hello Guest it is November 27, 2026, 05:56:28 PM
Author Topic: Gcode or Vb to update tool table after probing tool length offset  (Read 28483 times)
Re: Gcode or Vb to update tool table after probing tool length offset
« Reply #10 on: December 07, 2012, 01:03:49 AM »
made a new m401 and have it sitting in the macro folder of my test setup for the cnc as I am currently away from where the actual machine is for a few days. Running it at the moment from the vb editor to test it .
« Reply #11 on: December 07, 2012, 05:50:47 AM »
forgot to add its in the macro folder in the profile i use as a testing profile. (all ports and pins mapped but running in demo mode without and drivers loaded or ESS plug in)
« Reply #12 on: December 07, 2012, 10:40:00 AM »
IF you are not cycling the M6t# then you will not see the number change for current tool and selected tool.
« Reply #13 on: December 10, 2012, 09:08:17 AM »
Ok had to put this down to get other issues sorted but now that my manual tool release brain is working nicely time to get back into measuring these tools!
So  I have pulled together a few different auto tool zero macros and really happy with this mashup as it has a few key protection features and leave the cnc in the state it was found in. The only issue is I am constantly hitting my z+ soft limit and getting movement that is not what I expect from the G53 command.
I will highlight the lines below to show you where I am having issues but it was my understanding that G53 is in machine coordinates and therefore any offset should have NO effect. With the 0 in the tool offset table I have no issues and the script runs well. Once the offset is set tho on the G53 to Z0 the cnc seems to want to go much higher ( I am assuming the offset value but have a +1mm soft limit on the z at the moment to stop my ball screw nut slamming into bearing block….)
I have tried many different work arounds but none worked well and I would prefer to fine the problem than have to back road methods to be honest.
'Author: Christopher Esser (Smokingman). Based on the work done by Greolt
' modded by jestah 10 dec 2012
' Define fixed parameters (Currently in Metric )
Tnumber      =  GetDRO(24)  ' gets current tool
ProbeDist     = "-50" 'Set the maximum distance to move the Z-axis before probe touches contact plate.
ProbeFeed     = "500"   'Set the first plunge speed for the probe
ProbeFeed2     = "30"   'Set the second plunge speed for the probe
Retract       = "0.5"    'Set distance to retract after probe (incremental move away from touch plate)
Retract2       = "0"    'Set distance to retract after probe ( in mech. coor.)
Xprobpos   = "100" 'Centre of tool sensor X in mech coor
Yprobpos   = "100" 'Centre of tool sensor Y in mech coor
' Declare Global Variables
Dim CurrentFeed
Dim CurrentAbsInc
Dim CurrentGmode
Dim StartingPoint
' Begin the Program
Call GetState
Call doProbe
Call RestoreState
' Get the Starting states
Sub GetState()
  CurrentFeed   = GetOemDRO(818)    ' Get the current feedrate to return to later
  CurrentAbsInc = GetOemLED(48)     ' Get the current G90/G91 state (Abs Coordinate Mode)
  CurrentGmode  = GetOemDRO(819)    ' Get the current G0/G1 state
  StartingPoint = GetOemDRO(85) - GetOemDRO(832) ' Get starting Z position in work coordinates (Z Machine Coord DRO - Z Fixture Orig Off DRO)
End Sub
' Restore the states
Sub RestoreState()
  Code "F" &CurrentFeed ' Returns to prior feed rate
  If CurrentAbsInc = 0 Then Code "G91" ' If G91 was in effect before then return to it
  If CurrentGMode = 0 Then Code "G0"   ' If G0 was in effect before then return to it
End Sub
' Probe routine
Sub doProbe()
'Check to see if the probe is already grounded or faulty
  If isActive(DIGITIZE) Then
    MsgBox "Ground fault in probe detected. Fix probe and try again. "
    Exit Sub
  End If
'Start the actual probe
code "G49" 'remove any tool offset (tried both of these options to stop hitting soft limits on z)
'SetToolParam(Tnumber,2,0)
'Code "G43 H" &Tnumber
Code "G0 G53 Z" & Retract2 ' ( this is where the movement hits the soft limits even with the above removing tool length offsets...?!??!?)
   While IsMoving()
     Wend
 Code "G0 G53 X" & Xprobpos
   While IsMoving()
     Wend
  Code "G0 G53 Y" & Yprobpos
    While IsMoving()
      Wend
  Code "F" &ProbeFeed        ' Set the probe plunge speed
  Code "G91 G31 Z" &ProbeDist ' Probing move using incremental move mode.
  While IsMoving()           ' Wait while it happens
  Wend
  ZProbePos = GetVar(2002)   ' Get the exact point the probe was hit
  If (ProbeDist+StartingPoint = ZProbePos) Then ' No contact was made during plunge
    Code "(Probe failed!)"
    Exit Sub
  End If
Code "G90 G0 Z" &ZProbePos ' Go back to that point. Always a very small amount of overrun.
  While IsMoving ()
  Wend
  Code "G91 G0 Z" & Retract      ' Retract
    Wend
  Code "F" &ProbeFeed2       ' Set the probe plunge speed
  Code "G91 G31 Z-" &Retract+0.5 ' Probing move using incremental move mode.
  Wend
  ZProbePos = GetVar(2002)   ' Get the axact point the probe was hit
  While IsMoving ()
  Wend
  SetToolParam(Tnumber,2,ZProbePos)
  Code "G0 G53 Z" & Retract2     ' Retract to mech zero Have seen this drive z- into the tool sensor but not recently so may have solved this somewhere
  While IsMoving ()
  Wend
Code "G43 H" &Tnumber' apply offset to tool
  Code "(Tool offset set)" 'is it possible to but the actual offset set in this box? not really a issue but would be nice  ;D
End Sub
macro working!
« Reply #14 on: December 11, 2012, 01:22:21 AM »
Ok I found a clean enough work around for this macro.... I tested it a few times today, ran well from VB editor but from MDI it would do even strange things, I have marked in blue where this would happen.
The odd thing was it would head DOWN and seemed to lump all of the blue lines together (down, x and y movement) at a very slow feed and travel until I got a servo tripping out or my hand hitting the estop.
Thinking that it should not run them all together I added sleeps(25) between and also a big sleep(500) and a small move off z abs zero and now it seems to run fine... I don't know what it was being so strange but so far after many tests it seems to work well!
Hope it us helpful to others!
' Author: Christopher Esser (Smokingman). Based on the work done by Greolt
' modded by jestah 4th dec 2012
ProbeDist     = "-200" 'Set the maximum distance to move the Z-axis before probe touches contact plate.
Xprobpos   = "2635.74" 'Centre of tool sensor X in mech coor
Yprobpos   = "31.64" 'Centre of tool sensor Y in mech coor' Declare Global Variables
Probeoffset = "0"' offset from probe top to table surface
Dim CurrentFeed
Dim CurrentAbsInc
Dim CurrentGmode
Dim StartingPoint
' Begin the Program
Call GetState
Call doProbe
Call RestoreState
Sub GetState()
End Sub
Sub RestoreState()
End Sub
' Probe routine
Sub doProbe()
sleep(500)
ActivateSignal(OUTPUT5) ' Dust hood up
'Code "G91 G0 Z-0.01"
Code "G90 G0 G53 Z" & Retract2 ' ( this is where the movement hits the solf limits even with the above removing tool lenght offsets...?!??!?)
   While IsMoving()
   Sleep(50)
     Wend
Tme = 0
While(GetOEMLED(822) = fulse)
Sleep(100)
Tme = Tme +.1
If(Tme > 2)Then
MsgBox("Hood up signal Timed out - please check!")
Exit Sub
End If
Wend
   While IsMoving()
   Sleep(50)
     Wend
    While IsMoving()
    Sleep(50)
      Wend
 Sleep(50)
  Wend
    Exit Sub
  End If
  While IsMoving ()
  Sleep(50)
  Wend
   Sleep(50)
 Wend
  Sleep(50)
Wend
  While IsMoving ()
 Sleep(50)
 Wend
  While IsMoving ()
  Sleep(50)
Wend
 DeActivateSignal(OUTPUT5)
  End Sub
