Mach Discussion => General Mach Discussion => Topic started by: jestah on December 06, 2012, 12:01:15 AM
Hi guys,
Ok next newbie question.... I am trying to update my tool table offsets but can’t for the life of me find any reference to how to update the tool table using VB.
I have found a few macros and have made one for my more basic manual tool change cnc that just zeros out the Z DRO but as I have got my sticky fingers on a small ATC cnc I would prefer to have the tools in the rack measured and offsets stored in the tool table so that while cutting it only has to grab a tool and avoid measuring each after the change.
I just need to know the code that will actually update the tool table, I have been searching but have not found any thing and my attempts to get it to work in MDI have been fruitless..
Once again many thanks in advance!
IN the Mach manual look up G10
IN The Mach programmers manual look up SetToolParam()
(;-)TP
Thanks for the point in the right direction, once i have the code done i will post it for all! well at least for the experts to pick to shreds :P
No worries Jestah - the experts would not do that. ;D
First you would have to FIND some experts to show it too (;-)
I would actually like it if people could pick my macros and vb to shreds as I have only really been learning a few months and cut and paste most things untill it works.... Slowly I am working out what each function is for but having many minds on a task tends to make a stronger product!
My code so far seems to work as expected apart from a few points:
Tnumber = getselectedtool() ' gets current tool
this line only returns the value of zero so I am wondering if i am using it right...
I also am using this line to make the offset changes
code "G10 L1 P" &Tnumber & "Z" &ZProbePos ' failing at the moment but maybe due to the zero for the tool number
Code "(Tool offset set)" ' Success! But is it possible to but the actual offset set in this box?
One of the last lines of code is a very basic call to the give a message, could this be set to display the actually offset applied? If so could you give me some pointers to how to do this?
Once this is working I would like to add a call in the start-up to remember the start point so I can return the tool to that point once this macro is done.
Many thanks and hope that once we get the last bugs sorted this code will be useful to others!
' on top of the X-Y plane at the Z zero position. Cutting tool acts as a probe.
' Operation steps:
' 1. Get current state (Feedrate, G90/G91, G0/G1, Plate Thickness, and Starting Point)
' 2. Check if probe is grounded. Restore state and exit if it is.
' 3. Check if spindle is running. Give option to abort if it is
' 5. Move probe down at a rate of "ProbeFeed" until "ProbeDist" is reached, set Z-DRO and retract the distance set in "Retract"
' If "ProbeDist" is reached before the probe is contacted, the state is restored and the Z-DRO is left unset
' Last updated: 6/12/12
' Author: Christopher Esser (Smokingman). Based on the work done by Greolt
' modded by jestah 6th dec 2012
' Define fixed parameters (Currently in Metric )
Tnumber = getselectedtool() ' getts current tool
ProbeDist = "-200" 'Set the maximum distance to move the Z-axis before probe touches contact plate.
ProbeFeed = "1000" 'Set the first plunge speed for the probe
ProbeFeed2 = "30" 'Set the second plunge speed for the probe
VerifyTimeout = "10" 'Set timeout to wait for probe verify in seconds
Retract = "0.5" 'Set distance to retract after probe (incremental move away from touch plate)
Retract2 = "0" 'Set distance to retract after probe ( in mech. coor.)
Xprobpos = "100" 'Centre of tool sensor X in mech coor
Yprobpos = "100" 'Centre of tool sensor Y in mech coor
' Declare Global Variables
Dim CurrentFeed
Dim CurrentAbsInc
Dim CurrentGmode
Dim PlateThickness
Dim StartingPoint
' Begin the Program
Call GetState
Call doProbe
Call RestoreState
' Get the Starting states
Sub GetState()
CurrentFeed = GetOemDRO(818) ' Get the current feedrate to return to later
CurrentAbsInc = GetOemLED(48) ' Get the current G90/G91 state (Abs Coordinate Mode)
CurrentGmode = GetOemDRO(819) ' Get the current G0/G1 state
PlateThickness = GetUserDRO(1151) ' Read contact plate thickness DRO
StartingPoint = GetOemDRO(85) - GetOemDRO(832) ' Get starting Z position in work coordinates (Z Machine Coord DRO - Z Fixture Orig Off DRO)
End Sub
' Restore the states
Sub RestoreState()
Code "F" &CurrentFeed ' Returns to prior feed rate
If CurrentAbsInc = 0 Then Code "G91" ' If G91 was in effect before then return to it
If CurrentGMode = 0 Then Code "G0" ' If G0 was in effect before then return to it
End Sub
' Probe routine
Sub doProbe()
' Check to see if the probe is already grounded or faulty
If isActive(DIGITIZE) Then
MsgBox "Ground fault in probe detected. Fix probe and try again. "
Exit Sub
End If
' Check to see if the spindle is running
If GetOemLED(11) Then
Begin Dialog SindleOn 16,32,180,96,"Spindle Running!"
OKButton 132,8,40,14
CancelButton 132,28,40,14
Text 12,8,120,40,"It appears the spindle is running! Select 'OK' to continue anyway or 'Cancel' to exit."
End Dialog
Dim Dlg1 As SindleOn
Button = Dialog (Dlg1)
If Button=0 Then
Code "(Auto Tool Zero Aborted!)"
Exit Sub
End If
End If
'Start the actual probe
Code "G0 G53 Z" & Retract2
Code "G0 G53 X" & Xprobpos
Code "G0 G53 Y" & Yprobpos
Code "F" &ProbeFeed ' Set the probe plunge speed
Beep ' Signal start of Z movement
Code "G91 G31Z" &ProbeDist ' Probing move using incremental move mode.
While IsMoving() ' Wait while it happens
Wend
ZProbePos = GetVar(2002) ' Get the axact point the probe was hit
If (ProbeDist+StartingPoint = ZProbePos) Then ' No contact was made during plunge
Code "(Probe failed!)"
Exit Sub
End If
Code "G0 Z" & Retract ' Retract
Code "F" &ProbeFeed2 ' Set the probe plunge speed
Code "G91 G31Z" &Retract+1 ' Probing move using incremental move mode.
Wend
Code "G90 G0 Z" &ZProbePos ' Go back to that point. Always a very small amount of overrun.
While IsMoving ()
Wend
Code "G0 G53 Z" & Retract2 ' Retract
While IsMoving ()
Wend
Code "(Tool offset set)" ' Success! but is it possible to but the actuall offset set in this box?
End Sub
IF you want the current tool you use
GetCurrentTool()
GetSelectedtool() is the tool number that is loaded into the buffer with the T# call the M6 call tansfers the Selected tool to the current tool status.
Just a thought, (;-) TP
So for this am I better to look at one of the tool number dros on screen for getting the current loaded tool?
is it also bad practus to call a macro from a macro?
what is the difference between a oem dro and standard dro?
tired GetCurrentTool() and it still retruns 0 ... hmmmm maybe im still not doing this right!
Where are you running this macro from ?
made a new m401 and have it sitting in the macro folder of my test setup for the cnc as I am currently away from where the actual machine is for a few days. Running it at the moment from the vb editor to test it .
forgot to add its in the macro folder in the profile i use as a testing profile. (all ports and pins mapped but running in demo mode without and drivers loaded or ESS plug in)
IF you are not cycling the M6t# then you will not see the number change for current tool and selected tool.
Ok had to put this down to get other issues sorted but now that my manual tool release brain is working nicely time to get back into measuring these tools!
So I have pulled together a few different auto tool zero macros and really happy with this mashup as it has a few key protection features and leave the cnc in the state it was found in. The only issue is I am constantly hitting my z+ soft limit and getting movement that is not what I expect from the G53 command.
I will highlight the lines below to show you where I am having issues but it was my understanding that G53 is in machine coordinates and therefore any offset should have NO effect. With the 0 in the tool offset table I have no issues and the script runs well. Once the offset is set tho on the G53 to Z0 the cnc seems to want to go much higher ( I am assuming the offset value but have a +1mm soft limit on the z at the moment to stop my ball screw nut slamming into bearing block….)
I have tried many different work arounds but none worked well and I would prefer to fine the problem than have to back road methods to be honest.
'Author: Christopher Esser (Smokingman). Based on the work done by Greolt
' modded by jestah 10 dec 2012
Tnumber = GetDRO(24) ' gets current tool
ProbeDist = "-50" 'Set the maximum distance to move the Z-axis before probe touches contact plate.
ProbeFeed = "500" 'Set the first plunge speed for the probe
Dim CurrentFeed
Dim CurrentAbsInc
Dim CurrentGmode
Dim StartingPoint
' Begin the Program
Call GetState
Call doProbe
Call RestoreState
Sub GetState()
End Sub
Sub RestoreState()
End Sub
' Probe routine
Sub doProbe()
'Check to see if the probe is already grounded or faulty
Exit Sub
End If
code "G49" 'remove any tool offset (tried both of these options to stop hitting soft limits on z)
'SetToolParam(Tnumber,2,0)
'Code "G43 H" &Tnumber
Code "G0 G53 Z" & Retract2 ' ( this is where the movement hits the soft limits even with the above removing tool length offsets...?!??!?)
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
Code "G91 G31 Z" &ProbeDist ' Probing move using incremental move mode.
Wend
ZProbePos = GetVar(2002) ' Get the exact point the probe was hit
Exit Sub
End If
While IsMoving ()
Wend
Code "G91 G0 Z" & Retract ' Retract
Wend
Code "G91 G31 Z-" &Retract+0.5 ' Probing move using incremental move mode.
Wend
While IsMoving ()
Wend
SetToolParam(Tnumber,2,ZProbePos)
Code "G0 G53 Z" & Retract2 ' Retract to mech zero Have seen this drive z- into the tool sensor but not recently so may have solved this somewhere
While IsMoving ()
Wend
Code "G43 H" &Tnumber' apply offset to tool
Code "(Tool offset set)" 'is it possible to but the actual offset set in this box? not really a issue but would be nice ;D
End Sub
Ok I found a clean enough work around for this macro.... I tested it a few times today, ran well from VB editor but from MDI it would do even strange things, I have marked in blue where this would happen.
The odd thing was it would head DOWN and seemed to lump all of the blue lines together (down, x and y movement) at a very slow feed and travel until I got a servo tripping out or my hand hitting the estop.
Thinking that it should not run them all together I added sleeps(25) between and also a big sleep(500) and a small move off z abs zero and now it seems to run fine... I don't know what it was being so strange but so far after many tests it seems to work well!
Hope it us helpful to others!
' modded by jestah 4th dec 2012
Xprobpos = "2635.74" 'Centre of tool sensor X in mech coor
Yprobpos = "31.64" 'Centre of tool sensor Y in mech coor' Declare Global Variables
Probeoffset = "0"' offset from probe top to table surface
Dim CurrentFeed
Dim CurrentAbsInc
Dim CurrentGmode
Dim StartingPoint
' Begin the Program
Call GetState
Call doProbe
Call RestoreState
Sub GetState()
End Sub
Sub RestoreState()
End Sub
' Probe routine
Sub doProbe()
sleep(500)
ActivateSignal(OUTPUT5) ' Dust hood up
'Code "G91 G0 Z-0.01"
Code "G90 G0 G53 Z" & Retract2 ' ( this is where the movement hits the solf limits even with the above removing tool lenght offsets...?!??!?)
While IsMoving()
Sleep(50)
Wend
Tme = 0
While(GetOEMLED(822) = fulse)
Sleep(100)
Tme = Tme +.1
If(Tme > 2)Then
MsgBox("Hood up signal Timed out - please check!")
Exit Sub
End If
Wend
While IsMoving()
Sleep(50)
Wend
While IsMoving()
Sleep(50)
Wend
Sleep(50)
Wend
Exit Sub
End If
While IsMoving ()
Sleep(50)
Wend
Sleep(50)
Wend
Sleep(50)
Wend
While IsMoving ()
Sleep(50)
Wend
While IsMoving ()
Sleep(50)
Wend
DeActivateSignal(OUTPUT5)
End Sub
