Hello Guest it is October 28, 2026, 09:23:27 AM
Author Topic: TIMER for activate an OUTPUT  (Read 7903 times)
« on: December 03, 2012, 09:58:36 PM »
Hello, I need a BRAIN to do this:
When I activate the OUTPUT1....
The brain sleep 2 seconds...
then activate the OUTPUT2 and keep ON until the OUTPUT1 is OFF
Any suggestion?
I tried with a timer but the OUTPUT2 turns ON when I activate the OUTPUT1.... 2 seconds after the OUTPUT 2 turn OFF
Re: TIMER for activate an OUTPUT
« Reply #1 on: December 04, 2012, 06:02:58 AM »
Worked is simulation mode
You will have to change the input to what you want.
« Reply #2 on: December 04, 2012, 08:10:00 AM »
Thank you it's working!
