Hello Guest it is November 12, 2026, 01:31:34 AM
Author Topic: Only part of Gcode active [Help]  (Read 8323 times)
« on: November 27, 2012, 11:14:18 PM »
Hello dear members,
Just started using a software called Aspire, to generate 3D toolpaths/routines.
However, Ive successfully managed to save the file as a gcode (saved it as mach2/3 arcs).
But when I upload it into mach3 there is only like 2-3 layers showing up. The rest of the simulation is not there.
When I simulate it in mach3, it starts the routine but after a while it stops and thats where the end of the simulation "picture" is (but, I can see from the list code that there are still more codes to follow).
But I do know that I have a correct code because I simulated it with a program called NCPlot. And it does as it should.
Any suggestions of what Im doing wrong?
Edit:
Seems like it stops at line 500, and I Believe thats the limit for trial version. However, this was included with the CNC I bought so this is very odd. Guess Ill have to Contact the seller.
This is hilarious, thought I was doing something wrong when I used sketchup with sketchucam. Stupid *********.
Thanks and cheers!
« Last Edit: November 27, 2012, 11:22:18 PM by freak174 »
Re: Only part of Gcode active [Help]
« Reply #1 on: November 27, 2012, 11:48:26 PM »
Welcome, your not the first one to get bit by the demo limit.
  •  9,377 9,377
« Reply #2 on: November 28, 2012, 05:15:46 AM »
Hi Freak174,
Welcome to the forum.
You can purchase the Mach3 licence from here http://www.machsupport.com/purchase.php
