Hello Guest it is November 13, 2026, 11:50:53 AM
Author Topic: G28.1 Z.500 (TOM) routine NOW works with G68 coord rotation in V.067  (Read 10955 times)
Not sure IF any one noticed BUT the G28.1 Z.500 routine will NOW run with G68 active.   I found it by accident today testing some old code on the latest dev version.
Thanks Brian and Company (;-),
Re: G28.1 Z.500 (TOM) routine NOW works with G68 coord rotation in V.067
« Reply #1 on: November 27, 2012, 09:34:18 PM »
I guess it is time to do an update!
Steve
Thanks TP for finding this
« Reply #2 on: February 20, 2013, 08:21:59 PM »
Are you running 067 on a daily basis?  066 is lock down.  If 067 is still in development, I don't want to turn it loose on my customers.
« Reply #3 on: February 20, 2013, 09:12:39 PM »
Yes Richard I have. CandCNC switched over a while back to Ver.067 to gain all the improvements they needed for their latest release. It has been working fine here.
« Reply #4 on: March 10, 2013, 01:47:30 PM »
After some testing, I found a fairly serious issue in .067.  When cutting a large file with lots of parts, mach will skip over some of the parts.  The G-code is fine.  I load the same file on a machine running .022 and it runs fine.  When I re-load on .067, it fails.  Tried different PC's and different machines with the same results.  The failure point is random.  Every now and then it will just skip a part.  The TOM routine runs, torch fires, torch shuts off, raises and moves to next part....almost as if the linear feed code is just missing.
