Hello Guest it is November 13, 2026, 09:38:07 AM
Author Topic: Brian can you get us the "Internal parameters" list?  (Read 11786 times)
« on: January 26, 2007, 10:59:43 AM »
Hey Brian,
   Can you post the "Internal Parameters" list for VB?? so we know what things are called and how to access them in our scripts.
Scott
Re: Brian can you get us the "Internal parameters" list?
« Reply #1 on: January 28, 2007, 09:17:43 PM »
I will work on converting it into something that you can read...
Here it fresh out of Mach3 :
if(parm == "ZMachine" )return MainPlanner->MachPositions[2];
    else
     if(parm == "XMachine" )return MainPlanner->MachPositions[0];
    else
    if(parm == "YMachine" )return MainPlanner->MachPositions[1];
    else
     if(parm == "Encoder1" )return MainPlanner->MPG.Positions[0];
    else
     if(parm == "Encoder2" )return MainPlanner->MPG.Positions[1];
    else
     if(parm == "Encoder3" )return MainPlanner->MPG.Positions[2];
     else
     if(parm == "Encoder4" )return MainPlanner->MPG.Positions[3];
    else
     if(parm == "MPG1" )return MainPlanner->MPG.Positions[4];
    else
     if(parm == "MPG2" )return MainPlanner->MPG.Positions[5];
    else
     if(parm == "MPG3" )return MainPlanner->MPG.Positions[6];
    else
    if(parm == "XScale" )return _setup.xscale;
    else
     if(parm == "YScale" )return _setup.yscale;
    else
     if(parm == "ZScale" )return _setup.zscale;
    else
     if(parm == "AScale" )return _setup.ascale;
    else
     if(parm == "BScale" )return _setup.bscale;
    else
     if(parm == "CScale" )return _setup.cscale;
     else
    if(parm == "FeedRate" )return MainPlanner->FeedRate;
     else
    if(parm == "Units" )return MainPlanner->Units;
    else
    if(parm == "StepsPerAxisX" )return MainPlanner->StepsPerAxis[ 0];
    else
    if(parm == "StepsPerAxisY" )return MainPlanner->StepsPerAxis[ 1];
    else
    if(parm == "StepsPerAxisZ" )return MainPlanner->StepsPerAxis[ 2];
    else
    if(parm == "StepsPerAxisA" )return MainPlanner->StepsPerAxis[ 3];
    else
    if(parm == "StepsPerAxisB" )return MainPlanner->StepsPerAxis[ 4];
    else
    if(parm == "StepsPerAxisC" )return MainPlanner->StepsPerAxis[ 5];
    else
    if(parm == "VelocitiesX" )return MainPlanner->Velocities[ 0];
    else
    if(parm == "VelocitiesY" )return MainPlanner->Velocities[ 1];
    else
    if(parm == "VelocitiesZ" )return MainPlanner->Velocities[ 2];
    else
    if(parm == "VelocitiesA" )return MainPlanner->Velocities[ 3];
    else
    if(parm == "VelocitiesB" )return MainPlanner->Velocities[ 4];
    else
    if(parm == "VelocitiesC" )return MainPlanner->Velocities[ 5];
    else
    if(parm == "AccelerationX" )return MainPlanner->Acceleration[ 0];
    else
    if(parm == "AccelerationY" )return MainPlanner->Acceleration[ 1];
    else
    if(parm == "AccelerationZ" )return MainPlanner->Acceleration[ 2];
    else
    if(parm == "AccelerationA" )return MainPlanner->Acceleration[ 3];
    else
    if(parm == "AccelerationB" )return MainPlanner->Acceleration[ 4];
    else
    if(parm == "AccelerationC" )return MainPlanner->Acceleration[ 5];
     else
    if(parm == "SpindleSpeed" )return MainPlanner->Spindle.SpindleSpeed;
    else
    if(parm == "ZInhibitOn" )return MainPlanner->g_ZInhibit;
    else
    if(parm == "ZInhibitDepth" )return MainPlanner->g_ZInhDepth;
    else
    if(parm == "SafeZ" )
       return MainPlanner->m_SafeZ;
    else
    if(parm == "XDRO" )return MainPlanner->XPosition;
    else
    if(parm == "YDRO" )return MainPlanner->YPosition;
    else
    if(parm == "ZDRO" )return MainPlanner->ZPosition;
    else
    if(parm == "ADRO" )return MainPlanner->APosition;
    else
    if(parm == "BDRO" )return MainPlanner->BPosition;
    else
    if(parm == "CDRO" )return MainPlanner->CPosition;
    else
    if(parm == "Repeats" )return MainPlanner->Repeats;
    else
    if(parm == "Boundry" )return MainPlanner->m_Boundries;
    else
    if(parm == "XRefPer" )return MainPlanner-> RefSpeed[0];
  else
  if(parm == "YRefPer" )return MainPlanner-> RefSpeed[1];
  else
  if(parm == "ZRefPer" )return MainPlanner-> RefSpeed[2];
  else
  if(parm == "ARefPer" )return MainPlanner-> RefSpeed[3];
  else
  if(parm == "BRefPer" )return MainPlanner-> RefSpeed[4];
  else
  if(parm == "CRefPer" )return MainPlanner-> RefSpeed[5];
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: January 28, 2007, 09:38:42 PM »
Hey Brian, this kinda stuff also:
Steps = GetParam("StepsPerAxisX")
Thanks Amigo,
Scott
« Reply #3 on: January 28, 2007, 10:03:31 PM »
Yup that is in the list
see here
Told you I would have to convert it into something that you can read ;)
Brian
www.machsupport.com
