Hello Guest it is October 23, 2026, 06:18:46 AM
Author Topic: Optical Switch Interface systems  (Read 31170 times)
« on: November 25, 2012, 07:29:56 PM »
* Anyone interested in completely integrated optical switch setups *
As people may or may not know, optical switches are far superior to mechanical switches (ie: +/- 0.005" accuracy or better, no switch bounce, no mechanical parts to wear out). If anyone is interested in setting up their CNC machine with optical switches let me know. I offer completely integrated OSi (optical switch interface) systems.
The standard OSi system includes:
-1 standard OSi board
-6 switches and mounting hardware
-cables for switches and breakout board (will accommodate for up to 48" axises)
-complete setup instructions for the hardware and Mach
-unlimited tech support if needed
The standard OSi board supports 3-axis machines, two switches per axis. One switch per axis doubles as home/limit. The These boards will interface with virtually any breakout board with home and limit switch inputs. Custom interface boards with any specified amount of optical switches can be made upon request.
Complete standard OSi systems starting at $200.00
(Prices vary depending on axis sizes over 48")
Custom OSi system pricing available upon request
For any questions or to order an OSi system please contact me at
Email: jimnim1234@aol.com
Thank you for your support,
-James N
