Hello Guest it is November 13, 2026, 11:05:06 AM
Author Topic: The keyboard shortcut for the A, B, C axis does anyone know  (Read 12333 times)
« on: November 23, 2012, 01:47:42 AM »
Could someone tell me which is the keyboard shortcut for the A, B, C axis, the spindle reset and feed reset in the program Mach3 newer version. I tried all the buttons on the keyboard and combination with CTRL ALT but I can not start A axis. It works with the jog screen and MDI command, but I want to move it by pressing key for A axis like X axis.
Thanks in advance
  •  9,377 9,377
Re: The keyboard shortcut for the A, B, C axis does anyone know
« Reply #1 on: November 23, 2012, 04:36:23 AM »
Try; Config / System Hotkeys.  (eg. click A++ then press your desired key, then repeat for the others etc. etc.)
« Reply #2 on: November 23, 2012, 04:40:16 AM »
It works. Thank you so much
