Hello Guest it is November 12, 2026, 03:56:09 AM
Author Topic: PCI Parallel not working  (Read 11658 times)
« on: November 19, 2012, 06:14:15 PM »
Hi, I have recently set-up my 3-axis to work with the Toshiba TB6560 controller. The wiring is correct as the remote control works but I am still unable to get the controller working with MACH3. I've been doing some research and I am using a PCI parallel card, I have been changing port addresses still with no luck. I'm running 64bit windows 7 and mach3mill.
Ill post some screenshots of the settings I currently have. Any help will be greatly appreciated.
Thanks in advance.
Dcattena
Re: PCI Parallel not working
« Reply #1 on: November 19, 2012, 06:18:49 PM »
Screenshots
« Reply #2 on: November 19, 2012, 06:20:41 PM »
MACH3 with a lpt port will NOT work in 64bit windows  It runs in 32bit mode ONLY.
Just a thought, (;-) TP
« Reply #3 on: November 19, 2012, 06:26:22 PM »
Really??? Even when i have selected run legacy plug and play? Is there any workarounds?
« Reply #4 on: November 19, 2012, 07:44:41 PM »
So if i reinstall to windows 7 32bit this will work 100%?
« Reply #5 on: November 19, 2012, 08:40:24 PM »
You may want to do a search on that on this site.
