Hello Guest it is October 22, 2026, 04:52:10 PM
Author Topic: Which post processor  (Read 17058 times)
« on: November 10, 2012, 09:47:50 AM »
I have a DIY CNC machine I built from "Build your own CNC machine", I have Vcarve Pro 6.5 and I use Mach 3. My question is which Mach 3 post processor should I use from the list offered in Vcarve? I have just been using the G code which is a .tap file. It works but my engraving is a little off and I am thinking it's cause I am not using the right post processor.  Thanks for any help.
Safe machining everyone
Re: Which post processor
« Reply #1 on: November 10, 2012, 09:53:54 AM »
It's unlikely that the post is your problem, but you should be using one of the Mach2_3 ... posts. Usually the ATC posts, if you want to do tool changes.
« Reply #2 on: November 10, 2012, 10:04:20 AM »
what do you mean tool changes? what during the middle of a cut? whats the difference between the ATC posts and the ARCS?
« Reply #3 on: November 10, 2012, 10:12:39 AM »
You always want to use the arc posts.
Use the ATC posts if you're using more than one tool in your g-code. The ATC posts add a toolchange command for mach3 to stop so you can change tools.
« Reply #4 on: November 10, 2012, 10:18:32 AM »
thanks. so far i have not figured out how to save more than one tool path at a time. does saving my tool path as an ATC automatically save all the tool paths i have generated?
« Reply #5 on: November 10, 2012, 10:22:46 AM »
Yes, but you need to select them all, and check the box that says "Output all visible toolpaths to one file"
« Reply #6 on: November 10, 2012, 10:26:35 AM »
Thanks vey much
