Hello Guest it is November 12, 2026, 02:13:44 AM
Author Topic: Blank wall re dxf files ??  (Read 15378 times)
« on: November 07, 2012, 04:29:39 PM »
Hi, new to the hobby, have built a desktop three axis machine using Mach3 through a Gecko540. I have the machine up and running using supplied g-code, works well, my problem is I have access to several dxf files but have no idea how to convert to g-code so Mach can run them. On reading everything I can find I suspect I have to somehow put them into Lazycam then convert to g-code for mill. Any help you can offer in laymans terms would be much appreciated.
Terry
Re: Blank wall re dxf files ??
« Reply #1 on: November 07, 2012, 05:13:45 PM »
There's a LazyCAM manual here.
http://www.machsupport.com/forum/index.php/topic,12078.0.html
Personally, I'd recommend something more powerful and user friendly.
Check out Vectric's Cut2D, or CamBam.
« Reply #2 on: November 07, 2012, 05:29:48 PM »
Thanks ger21 for the reply, I have the demo of Cambam and intend to purchase. Could you give me the steps I would need to use to convert in Cambam.
Terry
« Reply #3 on: November 07, 2012, 05:35:29 PM »
Sorry, I've never used it.
« Reply #4 on: November 07, 2012, 06:17:51 PM »
The CamBam site has video's and tutorials.
« Reply #5 on: November 07, 2012, 06:21:07 PM »
Terry , Cambam has a very nice manual. CNC has a fairly steep learning curve. MOST try to do it backwards because some salesman convinced them it was turnkey. and rarely does it work that way.  You cannot run the machine without Gcode. You either have to learn to manually program Gcode(not likely at first) or learn a CAM program that creates Gcode. To run the CAM program you need drawings. To create drawings you must learn the basics of a CAD program.
You just have to bite the bullet and start from the beginning and work your way back to the end results, machining a part. AND even when you get back to there you really need to understand what all the codes MEAN for your machine how else would you know if something is not right.
Just a thought, (;-) TP
« Last Edit: November 07, 2012, 06:23:16 PM by BR549 »
« Reply #6 on: November 08, 2012, 05:54:12 AM »
Attached is a quicky  to using Cambam.
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #7 on: November 09, 2012, 06:12:54 AM »
You can always drag and drop your dxf into the workspace with CamBam.
« Reply #8 on: November 13, 2012, 01:43:37 PM »
Thanks for the replies, thankyou Rich that gives me a start.
Terry
