Hello Guest it is October 11, 2026, 06:22:44 AM
Author Topic: Mach 3 running a K2 CNC KT2514  (Read 9031 times)
« on: November 06, 2012, 06:21:02 PM »
Does anyone have Mach 3 running a K2CNC KT2514? I have a 2008 with servos using the Gecko G320 DC servo drives and a K2 breakout board that I haven't identified yet. I'm just installing Mach 3 to this machine and I have it to the point where I can jog the DRO's with my arrow keys but I can't get any motor movement. Port configuration was easy enough but I'm not confident about any of my pin configurations for motor outputs, input signals, output signals and encoders. Can anyone provide me with this info? Keep in mind I'm relatively new to this technology.
Re: Mach 3 running a K2 CNC KT2514
« Reply #1 on: September 15, 2020, 12:59:26 PM »
hi there im running the same setup. Did you ever get it running? If so how did you figure out your ports and pins setup? Im in desperate need of help. I cant get any movement at all. Thanks!
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: September 15, 2020, 04:13:55 PM »
We need lots of pictures of the parts and current setup before we can help.
