Hello Guest it is November 12, 2026, 02:21:46 AM
Author Topic: M98 program call  (Read 9863 times)
M98 program call
« on: November 06, 2012, 02:43:50 PM »
Hi there,
I like to call so code from the main pgm that contains machine specific code.
Like a retract to a safe position ore a datum shift that holds the build upp extra head!!
The code must remain accessible for the cnc operators for little changes.
One solution is a M98!!
But in what folder must this sub-program being placed? And can I force it to a specified folder?
Another solution could be to write a macro!!
How can I make something like that?
Ore is there another better solution?
Thanks, StoMMie
Re: M98 program call
« Reply #1 on: November 06, 2012, 04:21:00 PM »
That type stuff is covered in the MACH3 manual, may want to give it a read.
Just a thought, (;-) TP
« Reply #2 on: November 07, 2012, 11:35:39 AM »
Hi BR549,
My glasses know I read the manual, but I basically do not know what I am looking for (the best way to solve this).,
So I you are willing to give me a hint into the right direction, I gladly read it again 8)
Thanks in advance
« Reply #3 on: November 07, 2012, 01:57:01 PM »
In the Mach3 manaul section 10.8.7 covers subroutines M98/99. The default directory to store subs is C:\mach3\subroutines.
The option is to store it anywhere you want then call it by path from the Gcode program.
Mcodes are discussed in part in section 10.9.1.  There a 3 other manuals that concern Mcodes(macros)
Customizing MAch2
CypressBasic programmers reference
Mach3 Programers reference
