Hello Guest it is November 13, 2026, 09:36:45 AM
Author Topic: Maximum file size.  (Read 11040 times)
Maximum file size.
« on: November 06, 2012, 02:09:33 PM »
Hi I have a problem.
upload a file of 275,250 lines of code. (10.2 MB). I click GOTO ZERO, the motors do not move well and lost the reference in all axes.
I click Cycle Start and the machine moves at intervals and the reference is lost on all axes. this does not happen when I use files of 2 MB.
To Mach3 Gcode size matter?
my settings
Gecko G540
10A 45V source
Pc Pentium 4    2.66GHz     1.25GB Ram
GeForce 7100 GS Graphics
motors 425 Oz-In
thank you very much
« Last Edit: November 06, 2012, 02:11:24 PM by pedropin »
Re: Maximum file size.
« Reply #1 on: November 06, 2012, 03:43:54 PM »
With large g-code files, you may need to turn off the toolpath display, as it's very resource intensive. Once you turn it off, everything should work fine.
« Reply #2 on: November 06, 2012, 07:54:54 PM »
Ger21 work with 4Th axis, clear 3D compass and A-Rotations Enable.
and works perfect.
Thank you very much for your help,
A friendly greeting from Colombia
PedroPin
