Hello
Guest
it is
November 13, 2026, 03:16:18 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Drawing software
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Drawing software (Read 12249 times)
Magicman
28
Drawing software
on:
November 04, 2012, 03:14:23 PM »
I am not sure if it is the drawing program, Ventrics 2d of mach3. I draw a circle 4.75 inches in diameter. Save and load into ventrics. create the code and load it into mach 3. now the machine cuts a circle 4.714 inches. I drew the circle with corel draw 11.
Logged
Magicman
28
Re: Drawing software
Reply #1 on:
November 04, 2012, 03:15:18 PM »
Oh yes and i measured my bit and it measures .493
Logged
ger21
6,295
Reply #2 on:
November 04, 2012, 03:29:48 PM »
Did you set the tool size in Cut2D to 0.493?
What material are you cutting?
Climb cut, or conventional?
Inside, or Outside?
What kind of machine?
There are about 100 things that can cause what you're seeing.
Logged
Magicman
28
Reply #3 on:
November 04, 2012, 05:37:36 PM »
Tool set to .5 , Melamine, climb cut, inside. 48 by 48 machine
Logged
ger21
6,295
Reply #4 on:
November 04, 2012, 06:06:21 PM »
What kind of machine?, not what size is it.
Logged
Magicman
28
Reply #5 on:
November 04, 2012, 06:32:15 PM »
Niot really a model name as it is made by a guy from vancouver.
Logged
SlikChit
21
Reply #6 on:
November 05, 2012, 11:02:22 AM »
Have you tried cutting on or outside the line/circle? You may need to adjust the offset of the tool path to achieve the correct diameter of the finished circle
Logged
Print
Pages:
1
Go Up
« previous
next »
